Hello, what are the chances of playing 3D Bluray ISO files with a Raspberry 4 (Kodi 19)? Currently the ISO files are only played in 2D.
So I still need my old Raspberry 3 with Kodi 18 in addition to play these files. Is a bit cumbersome.
With kind regards, kaernesto
Unfortunately this won’t be supported. This is because Pi has changed from supporting MMAL/OMX directly to interfacing MMAL with V4L2/GBM. You could just keep your current Pis on an older version.
If you want to run Kodi v19 with 3D MVC support, consider Vero 4K +, where it is supported.
