Raspberry Pi 2 issue [SOLVED by trying RC2]
Hello
I’m trying to instal OSMC on PI 2
I used WIndows installer from your website and last RC1
It hangs when I put the micro SD
I see the multicolor screen and then PI screen shows formatiing … it was stucked
I changed
gpu_mem=32
stil stucked … at 25% of the bar …
after 3 minutes it moved and said install failed : can’t mount root
EDIT : I just checked my SD in Windows and it’s non readable so I have no file or install.log
EDIT 2 : I’ve seen RC2 and install seems better
WHat Should I do
Many Thanks
Jacques From France
