So, RPi 3 can play h265 well?
Will I be able to plug n play my existing Pi 2 SD card into a 3 and itāll work? Or does it need a new OS install. Also will it need a new one in the future for 64bit support and if it does will you offer a conversion or something because I honestly think Iād rather stay 32bit than have to set up everything I have set up all over again.
This has been covered no more than five posts above yours, and is also explained on the blog post.
Is there any plans to make a Bluetooth version of the OSMC remote instead of the 2.4Ghz RF version?
\0/
Becoming a reseller would do the trick to get one, weeks fewer ![]()
Iām getting strange behavior using the OSMC_TGT_rbp2_20160130 image file with the Pi 3, the green LED flashes 5 times slowly then 4 times quickly over and over, the display is only displaying the fullscreen rainbow square. Doesnāt seem to be a hardware issue as the Pi will boot with the latest image of raspbian from the raspberry pi official website.
Am I using the correct image?
Hi David
As outlined in the blog, youāll need to update to the latest version of OSMC which will enable support for your Raspberry Pi. There will be a further update to enable the new Pi 3 functionality (LED, WiFi, BT) soon. After this is added, weāll produce a new, directly compatible image for Pi 3.
So do I need to update with the SD card in a Pi 2 then transfer the SD card to the Pi 3 as the Pi 3 wonāt boot to allow me to update. Not sure I like the new SD card slot on the Pi 3, Iām used to the Pi 2 having a springy type holder rather than just a push fit.
Yes, that would be the easiest way to get up and running for now.
Sorry to be a pain, just done a fresh install on a Pi 2 ready to transfer to the 3, but Iām now getting āUpdate error check log for detailsā on startup and āAdd-on error check log for detailsā if I do a manual check. My log files are here if you have any time to check them http://paste.osmc.io/gukumereza
I have also tried the card in the 3 again after doing the fresh install just in case the update was picked up, Iām getting the same behavior with the LEDās but no Rainbow square on the TV now.
Have you searched? I am mobile, but you should find the solution quite easily, itās been mentioned several times today.
No I hadnāt to be honest, my brain was linking the problem to the Pi 3 which I didnāt think would be being discussed yet. Thankfully Australia has come to my rescue, damn leap years.
Thank you Sam
Regards Dave
Hi Sam,
Do you have anywhere to download your latest versions as boot.tar.xz and root.tar.xz?
I make a dual-boot Recalbox + OSMC NOOBs image and want to run the latest OSMC in it.
Those are NOOBs files. Theyāll be updated when the new hardware enablement update is released.
Iām giving up for the evening, got OSMC updated through the Pi 2 by changing timezone. Restarted, checked for updates again just to be sure, none were available. Transferred the SD card to the Pi 3, on boot I just get a red LED on solid and the green LED flashes twice. There is no picture being outputted although my TV and AV receiver do recognise the video output as 1080p. Tried booting with no ethernet plugged in, and with ethernet, neither way worked but there were no lights on the port with ethernet plugged in. Transferring the SD back to the Pi 2 results in good boot sequence.
Regards Dave
So, If I understand this right:
You need a Pi2 to update the image on the SD card before it will work in a Pi3?
I donāt have a Pi2, Iāve tried with the latest image from the downloader (2016.01-1), but that doesnāt boot.
Is there a way I can get this to work now, or should I just wait.
Hello !
What about support of HD audio ? Is the pi 3 can passthrough dts HD or DD HD ?
Thankās for the job Sam, OSMC is really my favorite mediacenter !
I see no Updates even today
