A little over a year ago, we announced OSMC support for the new Raspberry Pi 2, a long sought successor to the original device which brought much needed speed improvements to the low cost, credit-sized card device.
I’ve written about the new possibilities the new revision opens up in the blog post. GUI performance is improved, and the faster CPU opens up some new possibilities for some HEVC content.
The Pi 3 is a nice upgrade, but the Vero 2 is still our flagship and is more suited for those that want the best of OSMC. The Vero 2 provides plenty of speed and should be faster than the Pi 3. The Pi 3 retains the same GPU as previous models, which means HEVC/H265 decoding must be done in software. While the new Pi will be able to play back more HEVC content than before, there will still be some content that it will struggle with.
The Vero 2 supports HEVC/H265 hardware accelerated decoding. Vero 2’s Android release will launch very shortly which will let you enjoy a number of Apps and we also have OSMC Cloud which will launch exclusively for Vero owners (all generations) in the Summer. We also provide long term support for the Vero with guaranteed performance and feature updates for three years and security updates for five years.
The Pi is a great low-cost, entry-level device to the world of OSMC, and always will be. And today there’s a little bit more bang for your buck!
You need to update your system via My OSMC to the latest version. We will have some hardware enablement updates (for WiFi and the new LEDs) later today.
But when you will separate RPi2 et RPi3 images, will we need to reinstall the new image or will we be able to use the same sdcard (and image) and maybe install/uninstall some specific packages ?
If we decide a 64-bit version is beneficial and we decide to release one, you will need to perform a re-installation to get the best performance. You will however be able to stick with the Pi 2 image. It is easy to make an OSMC backup via My OSMC if you decide to move to the new image.
I will make an announcement on the blog if we do this.
Ok I see.
The problem is i customized my installation (install ftp server et some other stuff) and migration will be annoying.
I’ll see when it will effective ^^
Thanks for your answers by the way.
