Hello.
i have a raspberry pi 3 and my movie’s are stutting like its loading ?
i do watch my movie’s with ““server”” share with windows folders… smb share…
i run osmc last version.
can somebody tell me how i can fix it?
Hello.
Can you try putting a problematic video on a usb drive/stick and plug it directly in to the rpi3 and play it.
let us know what happens.
Also,
To get a better understanding of the problem you are experiencing we need more information from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us.
i am sorry i am new to this.
i test it with usb and it work perfect!
Ok, so it is possibly a network issue.
Can you enable debug logging and play a network video please.
then upload the logs
can you please tell me how i can do this? i only have my rasp for like 5 hours haha
You could click the link i have posted twice and read the page.
give me a sec will do asp
http://paste.osmc.io/eyuwedubex
thats the link i got!
How are you powering this device?
with a usb 3a 5v
thats enough power
The cache option sometimes helps with network problems, even with Lan. Might wanna add/edit the advancedsettings file, see here http://kodi.wiki/view/HOW-TO:Modify_the_video_cache
Good starting point:
<advancedsettings>
<network>
<buffermode>1</buffermode>
<cachemembuffersize>41943040</cachemembuffersize>
<readbufferfactor>2.0</readbufferfactor>
</network>
</advancedsettings>
i put my sd card in my laptop and did this Start - type %APPDATA%\kodi\userdata but nothing happend and i cant find a userdata map on my sd card? pls help
You can access your Pi via ssh. ssh gives you a direct connection to your Pi with a command line. On mac, linux, ubuntu, etc just start the terminal and type ssh osmc@ip-of-the-pi. Password is osmc
On win you can use a program called putty for this
i will try tommorow or late tonight will come back if it works!
i iam login and now?
Someone needs to learn how to edit his postings!
You appear to have the same IP address as @Arne_Pelzer and a similar email address. Did you accidentally lock yourself out of your old account?
