Hi there! I have a Raspberry Pi 4 (4gb model), I tried using the OSMC installer to put the latest on a 16GB Micro SD. When I boot up the Pi with SD inserted, installation completes without error, then on the first reboot I get a sad face screen. Then every 5-10 seconds it reboots again to sad face. It does this perpetually.
Notes:
- This is a completely fresh install of OSMC
- I have tried November, October, and September releases all of which failed
- I’ve tried OSMC installer AND the Raspberry Imager, both fail
- I am using the recommended 3A Raspberry plug
- I tried with and without Keyboard plugged in, fails regardless
- I have nothing else plugged in (just SD card, monitor, and power)
- Raspberry firmware is up-to-date, and before this I had the Pi OS running fine on the system without issue
- I’ve tried using SD card to install the OS to a USB3, still fails
- I’ve tried a different 32 GB SD card, still fails
Any ideas?
