I have the OSMC installed on Raspberry Pi 4. It keeps asking to update. Each time I try to update I get an error: “An error occurred while installing the following package: 7-rbp-bootloader-osmc (4.1.0-3). Please report this problem on the OSMC forum…”. It appears the Media Center has updated to 2011.11-2 (kernel: Linux 5.10.32-1-osmc), and the device is running Kodi 19.3. How can this issue be resolved, so the update completes successfully?
Yes it does…
Maybe this is the error, you’re looking for:
dpkg: error processing package rbp4-mediacenter-osmc (–configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
Should I just reinstall rpb4-mediacenter-osmc via apt?
I am super confused, are these logs from a Raspberry Pi or a Vero?
Is it from a Raspberry Pi and you restored a fstab from a Vero?
Your fstab is borked, you could try to correct it as below but not sure if you can fully recover with that.
/dev/mmcblk0p1 /boot vfat defaults,noatime,noauto,x-systemd.automount 0 0
# rootfs is not mounted in fstab as we do it via initramfs. Uncomment for remount (slower boot)
#/dev/mmcblk0p2 / ext4 defaults,noatime 0 0
