Raspberry Pi - Disable LED diodes
It would be nice if OSMC have option to disable LED diodes on Raspberry Pi. I can disable them in /boot/config.txt by adding:
[pi4]
Disable the PWR LED
dtparam=pwr_led_trigger=none
dtparam=pwr_led_activelow=off
Disable the Activity LED
dtparam=act_led_trigger=none
dtparam=act_led_activelow=off
Disable ethernet port LEDs
dtparam=eth_led0=4
dtparam=eth_led1=4
Problem is that this get removed in few weeks and I have to do it again.
So that option to disable the Led don’t work I you add them to config-user.txt?
If they don’t work when added to config-user.txt my recommendation is to use a cron job to check if they are still in config.txt and if not add them
# Warning: do not edit this file, or it could prevent your OSMC system from starting.
# If you wish to make changes, you should do so via My OSMC or edit the config-user.txt file in this directory
It wolks perfectly with /boot/config-user.txt
Thank you very much
