When I played some 10 bit 720p/1080 bit mkv files on OSMC
there is terrible green artifacts / pixelations in the video that makes it unwatchable.
Also the 1080p 10bit playback was really slow.
I then tested the same videos on Libreelec and the videos play perfectly without any green artifacts,
Libreelec was also able to play the 1080p 10bit alot more smoothly (without slowdowns) compared to OSMC.
The videos also play without issue on my PC…
which means the files are not corrupted.
The same hardware acceleration settings is enabled on both setup
I tested this on the same Raspberry Pi 3B+, the only thing changed was swapping the microsd that contains OSMC or Libreelec
So why is this only happening in OSMC and is it fixable?
