I ran into this looking for something else, took a look and it seems pretty interesting.
I’ve read that the Raspberry Pi 3 uses the SD bus for WiFi as well, so overclocking it might increase the WiFi speed too.
Thanks for the response!
I personally don’t care abut the wifi since I’m on Pi 2, that’s just something I picked up from the Kodi forum.
I was more interested in performance gain due to the sdhost overclock.
I’ve seen quite a few test results and it looks pretty good.
I wanted to check with you guys since I know that OSMC pretty much has up to date kernel and this should be possible.
Definitely keen to hear results from those that have tried this. Are there any plans to make this overclock accessible through the MyOSMC Pi Overclock interface?
Comparing these results I can’t say that I’m seeing any special increase in SD card performance which should be visible.
There are three possibilities:
I’m doing something wrong
My card can’t achieve better performance
OSMC does not support SDhost overclocking yet
Any ideas guys?
I’d love to hear @sam_nazarko opinion.
Not sure if the forum has mangled your dtoverlay line (always use the formatted text option when pasting something like config.txt) but it doesn’t look right to me. It should be something like this, with a comma.
dtoverlay=sdhost,overclock_50=100
I have not tried this on recent kernels but when sdhost was first trialled las year I saw read throughput increase of over 70% with overclock_50=90 on my Pi 2. Eg read throughput went up from about 20MB/sec to 36MB/sec.
Yeah the forum mangled it, although on my side it looks normal, not like what you quoted.
It’s one under the other, no comma. dtoverlay=sdtweak overclock_50=100
I was sure I would see some increase but what I achieved is basically nothing.
Separate lines is incorrect. It must be on the same line with a comma, exactly as I showed in my example. The overclock option is an additional parameter on the same dtoverlay line.
Interesting, I saw on Kodi forums that some people used one under the other, didn’t know it was an additional parameter.
I’ll fix that and test again.
Thanks @DBMandrake !
BTW be careful with how much you overclock. Unlike overclocking your CPU too much which is just likely to lead to a freeze, overclocking sdhost too much can easily corrupt your file system.
@DBMandrake thanks for the warning!
I saw that with
core_freq=500
overclock_50=100
everything should work just fine, people had some higher overclocks which also worked.
I guess I’ll have to try it for myself and check if it’s stable.
The only thing that worries me for some reason is the update process.
I’ll have to run it with the overclock and see if it corrupts the file system or not.
This is what I managed to get with dtoverlay=sdhost,overclock_50=100: kB reclen write rewrite read reread rread rwrite 51200 4 1191 1569 5803 5642 5337 1794 51200 512 9513 10859 16200 16113 16133 9631 51200 16384 11083 10766 16152 15354 16006 11250
Can’t say that I’m to impressed with results.
How did you measure the read throughput?
Also which sd card are you using?
I was sure this sd card would be ok but that might not be the real case.
Thanks for that popcornmix!
I can’t even tell you how much I admire your work…
I’m sure you’ve seen a ton of questions like this one, but what card would be good for Kodi on raspberry pi?
I’ve went through quite a few tests and benchmarks, and read quite a lot, in the end I can’t say I can make a reasonable choice.
I chose the current one based on benchmarks and results of random read/write.
Would you be able to recommend one?
