Hi guys,
I’d previously had this setup working on an older build some months ago and recently redid my setup but I can’t seem to get this working.
The pHatDAC is usually setup by setting the sound card to HifiBerry DAC and then choosing the device in audio settings but this option is no longer available, has anyone else had this problem and know a solution?
I’ve confirmed the DAC is working by running and rune audio setup.
Any help would be much appreciated.
              Search for HifiBerry. You may need to download the overlay manually until the next update resolves this
              Ah, is there an issue with the overlay file at the moment then?  I’ll test it out tonight, thanks!
              Yep
This should be the solution until next update.
    All of the failing HifiBerry’s are using the same overlay - hifiberry-dac. I modified all of the soundcard overlays last week to allow dynamic loading and unloading, but in doing so I broke the hifiberry-dac version - sorry about that. I fixed it the next day, but @sam_nazarko  was unlucky enough to get the bad one. You may be able to patch up your system by downloading this fixed version  and overwriting your installed copy, otherwise I’m sure the next release will no longer have this problem.
              Just tried it. Worked perfectly guys, cheers all![quote=“ActionA, post:4, topic:16663, full:true”]
[/quote]
