I’m trying to update from OSMC 2021.11 to the latest version 2022.03 but getting following errors on my Raspi 2 (Vero 4k worked fine)
sudo apt-get update
sudo apt-get dist-upgrade
BEGIN failed–compilation aborted at /usr/share/debconf/frontend line 6.
dpkg: error processing archive /var/cache/apt/archives/libc6_2.28-110.4_armhf.deb (–unpack):
new libc6:armhf package pre-installation script subprocess returned error exit status 255
sudo dpkg --configure -a
Setting up linux-libc-dev:armhf (4.19.232-1) …
dpkg: dependency problems prevent configuration of libc6-dev:armhf:
libc6-dev:armhf depends on libc6 (= 2.28-110.4); however:
Version of libc6:armhf on system is 2.28-110.1.
dpkg: error processing package libc6-dev:armhf (–configure):
dependency problems - leaving unconfigured
Setting up libc-dev-bin (2.28-110.4) …
Processing triggers for libc-bin (2.28-110.1) …
libc6-dev:armhf
any ideas how to resolve this installation issue?
kind regards,
Sarge
reproduce the issue
upload the log set (all configs and logs!) either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Hello,
I just uploaded the log files for this issue.
https://paste.osmc.tv/oxodagoyik
thanks in advance,
Sarge
Looks like perls base install is corrupt, please:
sudo apt-get --fix-broken --reinstall install perl-base libperl5.28
Thanks Tom.
Perl is a large package and one of the most likely packages to be corrupted if an SD becomes problematic because it consists of so many files.
It seems like your SD card may be problematic.
Some SD cards are not genuine or have a lower capacity than advertised. Some simply fail over time.
Symptoms of SD cards not working correctly are:
- Read-only behaviour, or changes made not persisting
- A filesystem corruption error
Symptoms of counterfeit SD cards are:
- Writing works until a certain filesystem size is reached, thereafter, writes seem to cause issues where existing data is lost or newly written data is not preserved.
- SD card fails after a short amount of time.
Counterfeit cards are usually found on Amazon and eBay.
SD cards have a limited lifespan. I recommend you change SD card and suspect that issues will no longer persist with a good card. If you would like to be a good quality SD card purpose manufactured for OSMC, then you can find one in the Store.
Hello,
thanks for the tip. Tried the command but doesn’t work:
osmc@kodi:~$ sudo apt-get --fix-broken --reinstall install perl-base libperl5.28
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libc6-dev : Depends: libc6 (= 2.28-110.4) but 2.28-110.1 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
also
sudo apt --fix-broken install
doesn’t work
Maybe the fastest way is to reinstall from scratch with a new SD card as suggested by Sam
regards,
Sarge
