airvb
21 November 2021 08:26
1
Hello,
OSM version [2020.11-1]
My goal is to stream music from my phone to my raspi3/osmc
I follow the guide here :https://discourse.osmc.tv/t/how-to-set-up-bluetooth-audio/87908
The first step to connect via bluetooth the phone to raspi is ok .
I switch off " keep audio device"
Launch my music from the phone, no sound heared.
The music on Raspi is played on usb DAC ( who is working well is music coming from raspi! )
Any check i can do ?
If you are always going to stream to the USB, then you can edit /lib/systemd/system/bluealsa-aplay.service (sudo nano /lib/systemd/system/bluealsa-aplay.service) as follows:
[Unit]
Description=A2DP Playback
After=bluealsa.service syslog.service
Requires=bluealsa.service
StopWhenUnneeded=true
[Service]
ExecStartPre=/bin/sleep 3
ExecStart=/usr/bin/bluealsa-aplay -D front:CARD=Audio --profile-a2dp 00:00:00:00:00:00
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=A2DP-Playback
Restart=on-failure
[Install]
WantedBy=bluetooth.target
then
sudo systemctl daemon-reload
sudo systemctl restart bluealsa-aplay
This assumes your DAC is reported like this by aplay -L
default:CARD=Audio
USB2.0 High-Speed True HD Audio, USB Audio
Default Audio Device
USB cards are usually called ‘Audio’. If yours is different, substitute what aplay -L tells you.
airvb
21 November 2021 17:05
3
Thanks for yr reply !
The USB dac is reported by aplay like this
default:CARD=U0x267f0x10e2
USB Device 0x267f:0x10e2, USB Audio
Modify service as follow :
cat /lib/systemd/system/bluealsa-aplay.service
[Unit]
[Service]
#ExecStart=/usr/bin/bluealsa-aplay --profile-a2dp 00:00:00:00:00:00
ExecStart=/usr/bin/bluealsa-aplay -D front:CARD=U0x267f0x10e2 --profile-a2dp 00:00:00:00:00:00
Restart=on-failure
[Install]
Reboot,
And IT’S WORKING NOW !
BRAVO , thanks
