i’m hoping someone can help. Been running this setup for years. About a week ago my Pi started acting weird, lost time, dropped the mounted drives, wouldn’t play videos. Long story short, I think the SD card corrupted. New SD card, and fresh install of OSMC.
Now however, my Samsung TV (a 15 year old plasma, not smart) cannot detect the Pi as a CEC connected device. It detects my firestick, so I know the CEC is working.
Here’s what I’ve tried:
Fresh clean install of OSMC
Enabling the samsung remote option in MyOSMC
Reviewing and enabling the CEC settings in the device settings
Removing the powercord from the TV
Switching HDMI ports
Removing the powercord from everything at the same time, turning back on
Any suggestions on what to try now? The box is accessible through SSH or USB connected keyboard at this point in time.
Enable debug logging with CEC component logging and upload a log.
reproduce the issue
If you haven’t do so I’d try a different PSU on the Pi. A PSU on it’s way out can cause all kinds of strange problems with a Pi (Got the T-shirt, I have 4 x 3b’s doing different things )
Reviewing the logs myself, I see that ioctl CEC_TRANSMIT failed, researching this, I see that in the rebuilding of my Pi it would seem I plugged into a different HDMI out port the left most one, when I had been using the right most one before. I switched back, unplugged everything for a couple minutes, then miraculously it works. I think maybe only one HDMI port supports CEC?
That is, of course, a matter of perspective. The primary display output, hdmi-0, should be used; it is the port located directly next to the USB-C power port. The logs show that hdmi-1 was used.
