Raspotify not discoverable without credentials
I have to specify credentials in raspotify’s config file otherwise it’s not visible. However, when I do it’s also only visible if connected using the same account. I’d like it to be visible to all devices on the network regardless of the account.
This issue has already been reported on the raspotify github a month ago. But I figured it might be related to OSMC. Is it because vero is connected on the LAN and not the Wifi? Does it requires a special network configuration? There’s no firewall on OSMC, right? Any way to diagnose this?
How?
Did you contact the add-on maintainer?
I didn’t. How do I do that?
The GitHub you linked is a great place. Or the add-on official thread in the Kodi forums.
