[RC] [Addon] [Script-Error] Amazon Prime
Hello,
yesterday I installed the RC version of OSMC. Fresh installation comming from Alpha 4. I reinstalled my Addon including the Amazon Prime Addon made by AddonscriptorDE. On Alpha 4 everything worked fine. On RC I’m not able to login.
I know the Addon is from his beta respository and I know RC ins not final, but can you tell me if there is anything I can do to fix this or do I have to wait for an update of this addon?
Here a part of my Error-Log:
Thanks in advance
Please upload the log to http://paste.osmc.io
thanks
Here the Log:
http://paste.osmc.io/oluqodapeg.coffee
There’s something wrong with your internet connection. Are you behind a corporate firewall by any chance ?
Error Contents: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:581)>
This is saying verification of the web servers secure certificate failed - this would usually only ever happen if your connection attempt was being intercepted by a transparent proxy, or you were stuck in a captive portal / walled garden that is waiting for you to log in to a web page before giving you internet access.
Likewise:
00:10:25 T:2756699168  NOTICE: [plugin.video.youtube] Running: YouTube (5.0.9) on Helix (14.1) with Python 2.7.9
00:10:35 T:2808083488   ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 502
00:10:35 T:2808083488  NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
00:10:45 T:2808083488   ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 502
00:10:45 T:2808083488   ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
http://www.checkupdown.com/status/E502.html
The confusing thing is, that didn’t made any changes to the setup. I just switched from A4 to RC.
Youtube is working again.
That’s because the problem wasn’t with your install. It was something wrong with your internet connection. (Internet connection means anywhere between you and the server you’re trying to connect to…)
