With April update for pi3B+ the “Guide” key behaviour on the rc6-mce remote has changed.
Previously when playing a Video from file pressing this key would give the OSD of “player process info” (codec info?). It would also give the context menu for a USB mounted drive with the “remove safely option”. The “Guide” key doesn’t work like this any more, it gives the generic PVR not installed/configured information.
The diff between an old and working version of Lircmap.xml is below, when I copy the old version over the new version it works as before.
Is this an intentional change or an omission? I assume my change will be overwritten when I next update.
Any information appreciated, Thanks.
452c452
< <guide>KEY_EPG</guide>
> <title>KEY_EPG</title>
567,568c567
< <title>KEY_TITLE</title>
627,628c626
687,688c685
