Hi, I was listening to music when all of a sudden I had the frowny face and then the Vero 4k went into a reboot loop. I can’t get a debug log because it never gets to the home screen.
I believe it’s a power supply issue so is there a recommended power supply I can try purchasing?
Did you try connecting by SSH to obtain a debug log? There’s a dozen other things that could cause this, that would be far more likely than a PSU issue, that logs could indicate.
I think it’s a power supply problem because I found a similar power unit and it powers up with that one.
So I could still try and run a debug log but it seems to be the psu.
Is there one I can purchase that is recommended by OSMC? As I’m wary of using random psu with a device it wasnt designed to power. Thanks.
Can you show a photo of the alternative PSU that you are using?
Any peripherals, such as a USB hard drive attached?
Can you see this pic? It’s an old psu for a now TV thing. 100-240v
I have a USB gigabit ethernet converter plugged into the vero. No drives. Been working fine for ages.
It’s 5V output, so should work.
We can send you a new PSU
That would be great thanks. Top notch aftersales as usual. You want a DM?
Yes — or if your address is still the same just the order number here will do.
Nice. Thanks. It should be - Order #14567
While you’re here - just a quick one - is the next update going to fix some lip sync issues? I have various audio offsets required depending on file type. Thanks
Yes it is. If you know how to use SSH, then you can test it now.
To test this update:
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
Happy to report the new update has seemingly fixed all audio sync issues for me. Great job. Thanks.
