Received OSMC wifi-ac adapter - ISSUES
Just for the record: On 5 GHz arp traffic (effectively OSI Level 2) appears to work both ways, whereas only incoming ping traffic (OSI Level 3) gets through, with the return path being blocked somewhere.
Journalctl with auto configuration
We can see IPv4 online check failed…
Is there a reason why you insists on screen shots instead of cut/paste? Screen shots are hard to read, take extra bandwidth and are not searchable.
I have no internet connection so I can’t upload logs.
Sorry for inconvenience
If you mean that you don’t have a connection while testing, you could run the commands and redirect the output to a file. Then get your connection back (using 2.4 or wired) and cut/paste the output.
Example:
iwlist scan > iwlist.out 2>&1
When you get your connection back cut/paste the contents of iwlist.out, or upload (cut/paste would be better)
Ok thx I will
Hello some news…
Fresh install and tested with a new router and get it working out of box.
So i will do more test on netgear x6
Finally got my netgear r8000 router working flashed with “advanced tomato”
:smiley:
thanks to everybody
