Hello,
Just noticed a bug.
Trying to refresh movie details from the information screen is no longer working.
ie if the scraper comes up with the wrong movie for a file, I’m no longer able to change it. I’m unsure when it was last functioning properly. I’m confident it was ok following the update to v18.0, but don’t know if it’s been working or not since the last few updates (now on 2019.05-2).
Attached are the logs (I hope).
https://paste.osmc.tv/abutimitoy
Cheers,
lb
The scraper (TMDB) seems to be working for your files and I can see it parsing the information.
Maybe the scraper doesn’t have details for the file you are trying to scrape.
Looks like a bug – we have a fix for this.
Ooh, sweet!
Thanks for the prompt reply and outstanding service (and what I assume will be a quick fix).
lb
It will be ready in a few days.
Hopefully the issue is now addressed
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
Tested and seems to work well
