I think after the last updates from october I have a problem when playing any kind of videos.
It does not matter whether I play videos via addon, PVR or just a file. After about 3-4 seconds the refresh rate is switched. I set refresh rate switch in player settings to start/stop and delay after change in system to 0.5 seconds.
One vero4k+ is working with 1920x1080p@60Hz, the other with 3840x2160@60Hz.
Both switch after 3-4 seconds.
reproduce the issue
