Hi again,
I just received a new TV, a Sony XF9005.
Setup is as followed:
-> Vero 4K with an “old” 2TB USB 2.0 external drive goes via HDMI into my AVR the
-> Denon X1300w that puts the picture to my Sony TV
I had a 50 HZ TV before. In the Kodi settings i always had chosen “adjust refreshrate at start/stop”. With my new TV that provides 100/120 HZ, this option leads to a strange phenomenon: When starting a video (no matter if 1080p or 2160p) the TV doesnt recognize an input anymore. It goes black and the TV warns me that there is no input detected.
Turning the “adjust refreshrate” off let me playback videos fine, but every few seconds (frames?) I recognize a small stuttering (judder?). This was the case with my old TV but the refreshrate option fixed that for me completely.
So I wonder what the reason is, that my new TV (with a wider refreshrate range) doesnt work with that option on.
Some testing I did:
Watched a 1080p bluray via the PS4: no stuttering visible
Tested two other HDMI cables: no change
played around with “resolution” and “Framerate” settings (set to 2160p and 60 atm)
Im prestty sure im overlooking something here, so any help would be appreciated.
