Regenerate cache for specific image from CLI?
Is it possible to induce OSMC/Kodi to refresh the cache entry for a specific image from the command line, or by sending some signal that could be generated from the command line? At present I’m just deleting the cache entry for the image and waiting it to be regenerated when the OS tries to load it, but that depends on figuring out which specific entry matches the input file, and it causes a long delay when the image gets loaded.
I think your answer will probably be found in the Texture Cache Maintenance utility…
