When wanting to reinstall OSMC to Vero V do you just use the image file or the Linux Installer.
It is suggested to use the Linux Installer which will transfer the Image in the appropriate way to the USB stick for the installation.
You also can use other tools do write the image to the USB stick but installer is most save way
