Hello,
the installation tool doesn’t work for min. 2 yeras on macbooks.
From log file:
Imaging failed!
Messages are:
stdout:
stderr: 0:142: execution error: dd: /Users/tomas/Downloads/OSMC_TGT_vero3_20200204.img: Operation not permitted (1)
I’ve tried to launch as root but it doesn’t work (it doesn’t open);
I changed the app permision in Settings (full disk access);
I was only successful with Etcher, but my Vero 4k just ignore created USB flasdisk.
In troubleshooting is written:
Sometimes, Vero 4K may not boot from an SD card or USB stick even though you have prepared it. We recommend that you try and use another SD card or USB stick if you have one at hand.
- I tried 3 USBs
- Before removing the SD card, rename the file ‘kernel.img’ to ‘recovery.img’ - done
- Find a non-conductive pin, such as a toothpick. Put it in the round port nearest the HDMI port. You should hear a soft, audible click - Where? There is just an optical port
Any ideas?
Thx,
Tomas
