Remote control issue
I am having some issues with the original Remote Control included with the Vero4K. Most of the time is does not work but my TV’s Remote (Samsung QLED 2017 series) works instead. I am forced to use Kodi iOS remote as my TV’s remote cannot access all the Vero’s functions. What’s happening with the Vero4K remote? Is there any workaroung to make it work?
Thanks a lot,
Ruben
  • Remove the USB from Vero 4K / Pi
  • Hold Home and OK button for 5 seconds or so, then the blue LED will keep flashing.
  • Plug in the USB receiver and the LED should flash 3 times after 5 seconds, indicating successful pairing.
  • Power off Vero 4K / Pi for 2 minutes. Turn it back on. The remote should now work.
Thanks!!!
