Remote control stops working after tuning scrambled channel on TVHeadend
I’ve installed the latest version of OSMC, then after many tries to get TVHeadend works well on my Raspberry Pi2, I’m on the same issue.
When I try to change channel, if I tuning on a scrambled channel, even if SD or HD channel, the remote control stops to working. After many many tries to stop play of the channel I can use agaim my remote control. If I use an USB keyboard, it works like a charm. There is some issue with Lirc Daemon.
Are you using a USB based receiver? Perhaps isochronous DVB transfer
  • Ethernet + LIRC is too much for the device…
Maybe you’re right… But why if I use keyboard USB all things works fine?
Don’t know – it may be a problem with the remote you’re using.
I didn’t have this problem using the official OSMC remote, but have had problems when testing a Hama MCE remote.
sudo apt-get install usbutils && lsusb -V would let us know more and possibly let us give some advice.
So here the result of your command:
osmc@osmc:~$ sudo apt-get install usbutils && lsusb -V
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libasn1-8-heimdal libgssapi3-heimdal libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhx509-5-heimdal libkrb5-26-heimdal libroken18-heimdal libwind0-heimdal rbp2-image-4.4.13-5-osmc
Use 'apt-get autoremove' to remove them.
  usbutils
0 upgraded, 1 newly installed, 0 to remove and 13 not upgraded.
Need to get 197 kB of archives.
After this operation, 689 kB of additional disk space will be used.
Get:1 http://ftp.debian.org/debian/ jessie/main usbutils armhf 1:007-2 [197 kB]
Fetched 197 kB in 0s (297 kB/s)
Selecting previously unselected package usbutils.
(Reading database ... 37567 files and directories currently installed.)
Preparing to unpack .../usbutils_1%3a007-2_armhf.deb ...
Unpacking usbutils (1:007-2) ...
Setting up usbutils (1:007-2) ...
lsusb (usbutils) 007
So… What I’ve done?
So, I’ve chacked the remote control of my TV in CEC mode through HDMI cable. The TV is a 32" LG. I’ve tried cec-client and I don’t get any code for Exit button, useful with Compliance Theme. Any suggestions for a back function?
