This seems to be a problem with the dongle. I tried another RF remote control and it works fine. I don’t see it in the store, so I suppose it’s not possible to order just a replacement for the dongle? Not really about the money, but I already have two remotes + zero working dongles so it seems a bit silly to order another new remote and end up with 3 remotes + 1 dongle!
Your device is probably out of warranty; but it doesn’t matter. I’d be happy to send you a new dongle in the post free of charge. Unfortunately we haven’t been producing dongles for the old remote (no volume buttons) for some time. I have given all of the dongles that we have away as out of warranty replacements.
I appreciate the offer - the remotes are both old ones; and it’s definitely out of warranty (I think about 1.5 years old now). I’ll just order another one & retire the old ones!
(… ordered… thanks for having such reasonable international shipping rates!)
Once it hung up, i started mashing buttons and then looked for the blue light. I saw it blink once, then it wouldn’t blink anymore… I tried doing the home + OK button, but didn’t get any blue light…
I had to remove the battery from the remote for it to recover, then I put the USB dongle back in and it’s working again… It seems like the remote is crashing, so what’s the fix for that?
Following back up on this… I replaced the battery with a new one and it seemed to work better for a while. However now it’s back to doing the same thing…
Do these remotes eat batteries? Do I have a defective remote that is using more battery than it should? Right now I have to take the battery out and put it back in. Then it works for a while. If it was the battery it shouldn’t work long after I do this process.
