So, I performed the OSMC upgrade today on my Ras Pi 2 and now I’m having trouble with my MySQL database, which is on another machine.
For a while I had a problem where the skin was infinitely reloading. Discovered it was because of syncing the addon_data folder, which included skin info, so during the update, the changes were written locally. I copied the folders onto my NFS and have this resolved that issue.
But now I’m consistently getting a ERROR: Unable to open database: MyMusic56 [1049](Unknown database ‘MyMusic56’), and saying it cannot connect to the database at xxx.xxx.x.xx
After a while, I just completely wiped out all the databases that kodi was using and figured a fresh database creation would fix it. What’s strange is that, when booting the Pi, I can see that it creates the MyMusicXX and MyVideoXX databases (I dropped them earlier, so kodi has to be the one making them), but then it still throws the connection error.
I can ping the IP fine from osmc, and I can even browse to my files that are on the NFS and play them. The issue is just syncing with the database. I’m kind of at a loss here. I haven’t done a fresh install yet, but I’m getting the same issue with Kodi 16 on my windows machine too. (Didn’t have kodi on there before, just added to see if maybe it was a Pi-specific issue).
Thanks in advance for any help
