Dear Community,
I have a weird issue with my remote from a Vero 4K.
The Remote buttons for “return”, “stop” do not work anymore.
What I already did is
- Replace Battery with a new one
- Re-install the Vero 4K
- Pairing (several times)
Still the buttons do not work on the UI. When pressing the buttons the blue flash appears, so somehow they get triggered.
I also own another Vero, the 4K+ Version. When I use the Remote + USB on this machine the remote does not work either. So I believe this is a HW failure kind of thing.
Anyone a suggestion how to revitalize the remote?
Boris
P.S. @sam_nazarko The Last response to my ticket is from Feb,22nd. I am still waiting for feedback!
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
I responded to your ticket on 23/02.
Can you check your spam folder?
Hi @sam_nazarko,
no email since feb,22nd, checked Spam as well as recommended. Within the Ticket System I see only your reply from mentioned 22nd and nothing new. Would you like to get a screenshot?
Boris
@sam_nazarko
Hi Sam, sent you an direct message with screenshot. Maybe i miss something!
Thank you for your help,
Boris
@Tom_Doyle,
Hi Tom,
will do as mentioned and upload.
cheers
Boris
Dear All,
quick update: It seems that the USB Dongle is faulty. I paired both remotes with the first dongle an all remote buttons work. Doing the pair with both remotes on the second USB Dongle shows the error behavior. So from my point of view the Remote USB Dongle is faulty and not the remotes.
Boris
You can raise a support ticket for a new dongle.
ok, done! Can I close the topic or are you going to close it?
There is no “closing” just a “Solution” which I have done
