Hi, with OSMC in my LG TV CEC remote functionality works very well. Back button works without configuration, and I can redefine in remote.xml the color buttons!
But backward and forward buttons doesn’t works as I expected, so I enabled logs to configure it and I see that I have no idea if I can configure or not.
When I press a color code (supose blue) I see something like:
pressed XXX (blue) (47) // Note the two parenthesis, one with the pressed button in text (blue)
But when I press forward log show something like:
pressed forward (32) // Only one parenthesis, but the first string is really the correct key
The problem is that I haven’t the key string (blue in the first example) for the forward/backwards buttons, but it really knowns that is forward/backward (the first string is correct, but is no the key that I can configure in remote.xml)
Is there any possiblity to redefine forward/backward in this situation? (if needed, I can get some real logs)
PD: The problem is because forward and backwards buttons points to “sleep” and “SkipNext” actions and I want FastForward and rewind.
