I have a use case where it would be helpful to be able to resume the Vero via the remote from the “power off” state initiated via the Kodi GUI, but not sure if there is a way to do it?
My old kitchen TV is mostly served by an nVidia Shield tube version which is located in a nearby server cupboard, there is a single HDMI cable from the cupboard to the wall where the TV is mounted. I have a passive HDMI switch and I’m looking to set up the Vero as an additional device in the cupboard (its Kodi performance is much better than the Shield).
When I connect both devices to the switch, the Shield has exactly the functionality I need: I can put it to sleep, and the connection switches over to the Vero. If I then put the Vero in standby, I can resume the Shield via its remote. However, I’m then stuck as a I don’t know if there is a remote-based way to restore the Vero even though it’s physically still powered.
Any suggestions as to how best to manage this situation? Thanks.
