Remote stopped working
I don’t know if it’s related to the recent update. I checked the battery, it’s fine. Seems to be something elsec
https://paste.osmc.tv/gituletoze
Update: I can’t re-pair as the blue led on the remote is not becoming visible after pressing Home + OK
you won’t believe it. While the old battery was actually empty I overlooked a sticker on the back of the new cell. Remove it. Up again :blush:
