I have the most annoying problem with the remote control for my Vero 4k+:
When it works, it’s great. The range is good, the reaction to button presses is fine. And usually, it does work.
But on occasion, it does not. There are two “modes of failure”:
a) The “back” button doesn’t work, all the other buttons do
b) ONLY the “back” button works, all the other buttons do NOT work.
(I can still control the Vero by IR remote, therefore I know the unit itself hasn’t crashed.)
The problem is most often triggered by a reboot e.g. after a firmware update. Then it takes a sequence of shutting down and rebooting the Vero, and sooner or later it starts working again. It’s worth noting that rebooting and shutting down are not the same for this, often rebooting doesn’t help, while shutting down does. Right now I seem to be in a state where none of the two helps, I can get into either one of the failure modes, but I can’t get all the buttons working again at the same time.
It’s as if the remote is being detected as a different model or something. Or maybe it could be RF interference during some critical detection phase on power up?
Do you have any suggestions? I’ve come to fear every blue screen or planned reboot for afterward surely this jumping through hoops will start again… ![]()
Regards
Edit:
… just solved the problem for one more time:
It must have started when this morning my power went out for a few minutes. That was the Vero reboot that started the trouble again.
To recover, I pulled the power from the Vero and left it sitting for a few minutes. Then powered back up: “mode a)”, no back button.
One more reboot (not a power down): Bingo, both working again.
Before, I tried a sequence of power down and reboots but could only get from one failure state to the other. The letting it sit without power for a while seems to have done it for now.
