Remotely wake Vero 4K+ from suspend?
I have the Vero4K+/OSMC configured to suspend from the remote (long-press Home). Red LED turns on, and I can wake from the remote as well. Excellent!
Now I would like to be able to wake the device from Home Assistant. The Home Assistant documentation for Kodi only mentions to use JSON-CEC’s Activate command. But that doesn’t work for me; the red LED remains on, perhaps because CEC is not enabled because it didn’t work properly for me. Also the wake.py script is not triggered this way.
Is there a way to properly wake the Vero 4K+ from Home Assistant?
Tried JSon keypress?
Or via SSH.
Thanks! Simply sending Input.Home did the trick.
In Home Assistant the YAML looks like this:
- service: kodi.call_method
  data:
    entity_id: media_player.kodi_vero4k
    method: Input.Home
