I had pihole installed and working but now have a dedicated Pi for this, could someone advise which of the following can be removed and which is required
The following dependencies may have been added by the Pi-hole install:
dhcpcd5 git iproute2 whiptail dnsutils cron curl iputils-ping lsof netcat psmisc sudo unzip wget idn2 sqlite3 libcap2-bin dns-root-data libcap2 lighttpd php7.3-common php7.3-cgi php7.3-sqlite3 php7.3-xml php7.3-json php7.3-intl
The following packages are not installed on my Vero4k+ with Buster (development):
dpkg-query: no packages found matching dhcpcd5
dpkg-query: no packages found matching git
dpkg-query: no packages found matching iputils-ping
dpkg-query: no packages found matching lsof
dpkg-query: no packages found matching netcat
dpkg-query: no packages found matching unzip
dpkg-query: no packages found matching idn2
dpkg-query: no packages found matching sqlite3
dpkg-query: no packages found matching dns-root-data
dpkg-query: no packages found matching php7.3-common
dpkg-query: no packages found matching php7.3-cgi
dpkg-query: no packages found matching php7.3-sqlite3
dpkg-query: no packages found matching php7.3-xml
dpkg-query: no packages found matching php7.3-json
dpkg-query: no packages found matching php7.3-intl
