http://without-systemd.org/wiki/index.php/Main_Page
I don’t want to run this garbage code on my hardware, however unlike in ubuntu/debian where it it still possible to switch the init system back to upstart/sysVinit, osmc does not allow replacing systemd:
apt-get install upstart
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
cgmanager cpio ifupdown initramfs-tools iproute2 klibc-utils libcgmanager0 libjson0 libklibc libnih-dbus1 libnih1 libpam-systemd libsystemd0 makedev
mountall plymouth systemd systemd-shim
Suggested packages:
libarchive1 ppp rdnssd bash-completion iproute2-doc desktop-base plymouth-themes systemd-ui pm-utils python3 graphviz upstart-monitor
Recommended packages:
isc-dhcp-client dhcp-client libatm1
The following packages will be REMOVED:
rbp2-device-osmc systemd-sysv
cgmanager cpio ifupdown initramfs-tools iproute2 klibc-utils libcgmanager0 libjson0 libklibc libnih-dbus1 libnih1 makedev mountall plymouth systemd-shim
upstart
libpam-systemd libsystemd0 systemd
3 upgraded, 16 newly installed, 2 to remove and 78 not upgraded.
Need to get 4159 kB/4511 kB of archives.
After this operation, 5383 kB of additional disk space will be used.
Fetched 4159 kB in 11s (372 kB/s)
(Reading database ... 30205 files and directories currently installed.)
Removing rbp2-device-osmc (1.3.3) ...
WARNING: You have tried to remove a package that is essential to OSMC's operation.
To undo these changes, run 'sudo apt-get -f install'.
dpkg: error processing package rbp2-device-osmc (--remove):
subprocess installed pre-removal script returned error exit status 1
rbp2-device-osmc
Is there a way to remove it or am I better off looking for other distro to run my Kodi on such as ARMbian.
