Completely bewildered.
Moved from FTTC to FTTP very nice, 4 times as fast…
But my new router rather than providing 192.168.0.xxx
addresses issues them in the range 192.168.108.xxx
Every other device has picked up a new IP address.
Not Vero4K
Any suggestions as to how I can force a refresh
Even after a reboot? Maybe try…
sudo ifconfig eth0 down && sudo ifconfig eth0 up
and if that doesn’t renew it try manually setting network settings in the My OSMC add-on and then setting it back to DHCP after it is working set static.
Reboot had been tried.
Like a clown I hadn’t thought to manually reset the gateway.
I did following your suggestion and of course Vero4K did its job. All sorted.
(OK, now debating getting a Vero 5 to plug into my new projector…)
