Hi!
My PCTV 72e does not work anymore under Linux (not used for about 2 year since i moved in a new flat). It works perfectly under Windows7 and i can view hd channels too. It’s weird as if I reboot in Linux after used it in Windows it works flawlessly. I tried older linux distro I used from 2 to 5 years ago with no success, so I suspect that there it may be a problem related to high signal strength (i loose the mobile antenna, so I cannot verify) that is handled by the windows driver but not by the linux one.
Anyway the PCTV 72e never had a good sensitivity (got about half of channels of a normal tv) so I decided to buy a new one with a very good linux support and sensitivity good to run a rbpi2 tv backend/osmc 24h.
Someone suggested me the PCTV 292e but it’s quite expensive (i do not need dvb-c so i guess some model dvb-t2 only may be cheaper). I read some info about RTL2832U+R820T based stick too and SDR would be a nice feature but only if it meets my requirements.
Suggestions?
Nico
