BGIYYZ
26 February 2023 02:04
21
This was #4
Testing … (interrupt to exit)
Event: time 1677376978.726669, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0041
Event: time 1677376978.726669, type 1 (EV_KEY), code 353 (KEY_SELECT), value 1
Event: time 1677376978.726669, -------------- SYN_REPORT ------------
Event: time 1677376978.846651, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0041
Event: time 1677376978.846651, type 1 (EV_KEY), code 353 (KEY_SELECT), value 0
Event: time 1677376978.846651, -------------- SYN_REPORT ------------
Going into #5 didn’t respond when I pushed ok
BGIYYZ:
This was #4
I need the full output for the one responding.
BGIYYZ
26 February 2023 02:10
23
Here you go…again, pushing ok 3 times
Testing ... (interrupt to exit)
osmc@osmc:~$ evtest
No device specified, trying to scan all of /dev/input/event*
Not running as root, no devices may be available.
Available devices:
/dev/input/event0: gpio_keypad
/dev/input/event1: aml_vkeypad
/dev/input/event2: cec_input
/dev/input/event3: input_btrcu
/dev/input/event4: HAOBO Technology USB Composite Device
/dev/input/event5: HAOBO Technology USB Composite Device
/dev/input/event6: meson-ir
/dev/input/event7: lircd
Select the device event number [0-7]: 4
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x4842 product 0x1 version 0x201
Input device name: "HAOBO Technology USB Composite Device"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 1 (KEY_ESC)
Event code 2 (KEY_1)
Event code 3 (KEY_2)
Event code 4 (KEY_3)
Event code 5 (KEY_4)
Event code 6 (KEY_5)
Event code 7 (KEY_6)
Event code 8 (KEY_7)
Event code 9 (KEY_8)
Event code 10 (KEY_9)
Event code 11 (KEY_0)
Event code 12 (KEY_MINUS)
Event code 13 (KEY_EQUAL)
Event code 14 (KEY_BACKSPACE)
Event code 15 (KEY_TAB)
Event code 16 (KEY_Q)
Event code 17 (KEY_W)
Event code 18 (KEY_E)
Event code 19 (KEY_R)
Event code 20 (KEY_T)
Event code 21 (KEY_Y)
Event code 22 (KEY_U)
Event code 23 (KEY_I)
Event code 24 (KEY_O)
Event code 25 (KEY_P)
Event code 26 (KEY_LEFTBRACE)
Event code 27 (KEY_RIGHTBRACE)
Event code 28 (KEY_ENTER)
Event code 29 (KEY_LEFTCTRL)
Event code 30 (KEY_A)
Event code 31 (KEY_S)
Event code 32 (KEY_D)
Event code 33 (KEY_F)
Event code 34 (KEY_G)
Event code 35 (KEY_H)
Event code 36 (KEY_J)
Event code 37 (KEY_K)
Event code 38 (KEY_L)
Event code 39 (KEY_SEMICOLON)
Event code 40 (KEY_APOSTROPHE)
Event code 41 (KEY_GRAVE)
Event code 42 (KEY_LEFTSHIFT)
Event code 43 (KEY_BACKSLASH)
Event code 44 (KEY_Z)
Event code 45 (KEY_X)
Event code 46 (KEY_C)
Event code 47 (KEY_V)
Event code 48 (KEY_B)
Event code 49 (KEY_N)
Event code 50 (KEY_M)
Event code 51 (KEY_COMMA)
Event code 52 (KEY_DOT)
Event code 53 (KEY_SLASH)
Event code 54 (KEY_RIGHTSHIFT)
Event code 55 (KEY_KPASTERISK)
Event code 56 (KEY_LEFTALT)
Event code 57 (KEY_SPACE)
Event code 58 (KEY_CAPSLOCK)
Event code 59 (KEY_F1)
Event code 60 (KEY_F2)
Event code 61 (KEY_F3)
Event code 62 (KEY_F4)
Event code 63 (KEY_F5)
Event code 64 (KEY_F6)
Event code 65 (KEY_F7)
Event code 66 (KEY_F8)
Event code 67 (KEY_F9)
Event code 68 (KEY_F10)
Event code 69 (KEY_NUMLOCK)
Event code 70 (KEY_SCROLLLOCK)
Event code 71 (KEY_KP7)
Event code 72 (KEY_KP8)
Event code 73 (KEY_KP9)
Event code 74 (KEY_KPMINUS)
Event code 75 (KEY_KP4)
Event code 76 (KEY_KP5)
Event code 77 (KEY_KP6)
Event code 78 (KEY_KPPLUS)
Event code 79 (KEY_KP1)
Event code 80 (KEY_KP2)
Event code 81 (KEY_KP3)
Event code 82 (KEY_KP0)
Event code 83 (KEY_KPDOT)
Event code 85 (KEY_ZENKAKUHANKAKU)
Event code 86 (KEY_102ND)
Event code 87 (KEY_F11)
Event code 88 (KEY_F12)
Event code 89 (KEY_RO)
Event code 90 (KEY_KATAKANA)
Event code 91 (KEY_HIRAGANA)
Event code 92 (KEY_HENKAN)
Event code 93 (KEY_KATAKANAHIRAGANA)
Event code 94 (KEY_MUHENKAN)
Event code 95 (KEY_KPJPCOMMA)
Event code 96 (KEY_KPENTER)
Event code 97 (KEY_RIGHTCTRL)
Event code 98 (KEY_KPSLASH)
Event code 99 (KEY_SYSRQ)
Event code 100 (KEY_RIGHTALT)
Event code 102 (KEY_HOME)
Event code 103 (KEY_UP)
Event code 104 (KEY_PAGEUP)
Event code 105 (KEY_LEFT)
Event code 106 (KEY_RIGHT)
Event code 107 (KEY_END)
Event code 108 (KEY_DOWN)
Event code 109 (KEY_PAGEDOWN)
Event code 110 (KEY_INSERT)
Event code 111 (KEY_DELETE)
Event code 113 (KEY_MUTE)
Event code 114 (KEY_VOLUMEDOWN)
Event code 115 (KEY_VOLUMEUP)
Event code 116 (KEY_POWER)
Event code 117 (KEY_KPEQUAL)
Event code 119 (KEY_PAUSE)
Event code 121 (KEY_KPCOMMA)
Event code 122 (KEY_HANGUEL)
Event code 123 (KEY_HANJA)
Event code 124 (KEY_YEN)
Event code 125 (KEY_LEFTMETA)
Event code 126 (KEY_RIGHTMETA)
Event code 127 (KEY_COMPOSE)
Event code 128 (KEY_STOP)
Event code 129 (KEY_AGAIN)
Event code 130 (KEY_PROPS)
Event code 131 (KEY_UNDO)
Event code 132 (KEY_FRONT)
Event code 133 (KEY_COPY)
Event code 134 (KEY_OPEN)
Event code 135 (KEY_PASTE)
Event code 136 (KEY_FIND)
Event code 137 (KEY_CUT)
Event code 138 (KEY_HELP)
Event code 139 (KEY_MENU)
Event code 140 (KEY_CALC)
Event code 142 (KEY_SLEEP)
Event code 144 (KEY_FILE)
Event code 150 (KEY_WWW)
Event code 152 (KEY_SCREENLOCK)
Event code 155 (KEY_MAIL)
Event code 156 (KEY_BOOKMARKS)
Event code 158 (KEY_BACK)
Event code 159 (KEY_FORWARD)
Event code 161 (KEY_EJECTCD)
Event code 163 (KEY_NEXTSONG)
Event code 164 (KEY_PLAYPAUSE)
Event code 165 (KEY_PREVIOUSSONG)
Event code 166 (KEY_STOPCD)
Event code 167 (KEY_RECORD)
Event code 168 (KEY_REWIND)
Event code 169 (KEY_PHONE)
Event code 171 (KEY_CONFIG)
Event code 172 (KEY_HOMEPAGE)
Event code 173 (KEY_REFRESH)
Event code 174 (KEY_EXIT)
Event code 176 (KEY_EDIT)
Event code 177 (KEY_SCROLLUP)
Event code 178 (KEY_SCROLLDOWN)
Event code 179 (KEY_KPLEFTPAREN)
Event code 180 (KEY_KPRIGHTPAREN)
Event code 181 (KEY_NEW)
Event code 182 (KEY_REDO)
Event code 183 (KEY_F13)
Event code 184 (KEY_F14)
Event code 185 (KEY_F15)
Event code 186 (KEY_F16)
Event code 187 (KEY_F17)
Event code 188 (KEY_F18)
Event code 189 (KEY_F19)
Event code 190 (KEY_F20)
Event code 191 (KEY_F21)
Event code 192 (KEY_F22)
Event code 193 (KEY_F23)
Event code 194 (KEY_F24)
Event code 206 (KEY_CLOSE)
Event code 207 (KEY_PLAY)
Event code 208 (KEY_FASTFORWARD)
Event code 209 (KEY_BASSBOOST)
Event code 210 (KEY_PRINT)
Event code 212 (KEY_CAMERA)
Event code 216 (KEY_CHAT)
Event code 217 (KEY_SEARCH)
Event code 219 (KEY_FINANCE)
Event code 223 (KEY_CANCEL)
Event code 224 (KEY_BRIGHTNESSDOWN)
Event code 225 (KEY_BRIGHTNESSUP)
Event code 228 (KEY_KBDILLUMTOGGLE)
Event code 229 (KEY_KBDILLUMDOWN)
Event code 230 (KEY_KBDILLUMUP)
Event code 231 (KEY_SEND)
Event code 232 (KEY_REPLY)
Event code 233 (KEY_FORWARDMAIL)
Event code 234 (KEY_SAVE)
Event code 235 (KEY_DOCUMENTS)
Event code 240 (KEY_UNKNOWN)
Event code 241 (KEY_VIDEO_NEXT)
Event code 244 (KEY_BRIGHTNESS_ZERO)
Event code 256 (BTN_0)
Event code 353 (KEY_SELECT)
Event code 354 (KEY_GOTO)
Event code 358 (KEY_INFO)
Event code 362 (KEY_PROGRAM)
Event code 366 (KEY_PVR)
Event code 370 (KEY_SUBTITLE)
Event code 372 (KEY_ZOOM)
Event code 374 (KEY_KEYBOARD)
Event code 376 (KEY_PC)
Event code 377 (KEY_TV)
Event code 378 (KEY_TV2)
Event code 379 (KEY_VCR)
Event code 380 (KEY_VCR2)
Event code 381 (KEY_SAT)
Event code 383 (KEY_CD)
Event code 384 (KEY_TAPE)
Event code 386 (KEY_TUNER)
Event code 387 (KEY_PLAYER)
Event code 389 (KEY_DVD)
Event code 392 (KEY_AUDIO)
Event code 393 (KEY_VIDEO)
Event code 396 (KEY_MEMO)
Event code 397 (KEY_CALENDAR)
Event code 398 (KEY_RED)
Event code 399 (KEY_GREEN)
Event code 400 (KEY_YELLOW)
Event code 401 (KEY_BLUE)
Event code 402 (KEY_CHANNELUP)
Event code 403 (KEY_CHANNELDOWN)
Event code 405 (KEY_LAST)
Event code 407 (KEY_NEXT)
Event code 408 (KEY_RESTART)
Event code 409 (KEY_SLOW)
Event code 410 (KEY_SHUFFLE)
Event code 412 (KEY_PREVIOUS)
Event code 416 (KEY_VIDEOPHONE)
Event code 417 (KEY_GAMES)
Event code 418 (KEY_ZOOMIN)
Event code 419 (KEY_ZOOMOUT)
Event code 420 (KEY_ZOOMRESET)
Event code 421 (KEY_WORDPROCESSOR)
Event code 422 (KEY_EDITOR)
Event code 423 (KEY_SPREADSHEET)
Event code 424 (KEY_GRAPHICSEDITOR)
Event code 425 (KEY_PRESENTATION)
Event code 426 (KEY_DATABASE)
Event code 427 (KEY_NEWS)
Event code 428 (KEY_VOICEMAIL)
Event code 429 (KEY_ADDRESSBOOK)
Event code 430 (KEY_MESSENGER)
Event code 431 (KEY_DISPLAYTOGGLE)
Event code 432 (KEY_SPELLCHECK)
Event code 433 (KEY_LOGOFF)
Event code 439 (KEY_MEDIA_REPEAT)
Event code 442 (KEY_IMAGES)
Event code 576 (KEY_BUTTONCONFIG)
Event code 577 (KEY_TASKMANAGER)
Event code 578 (KEY_JOURNAL)
Event code 579 (KEY_CONTROLPANEL)
Event code 580 (KEY_APPSELECT)
Event code 581 (KEY_SCREENSAVER)
Event code 582 (KEY_VOICECOMMAND)
Event code 592 (KEY_BRIGHTNESS_MIN)
Event code 593 (KEY_BRIGHTNESS_MAX)
Event type 2 (EV_REL)
Event code 6 (REL_HWHEEL)
Event type 3 (EV_ABS)
Event code 32 (ABS_VOLUME)
Value 0
Min 0
Max 668
Event type 4 (EV_MSC)
Event code 4 (MSC_SCAN)
Event type 17 (EV_LED)
Event code 0 (LED_NUML) state 0
Event code 1 (LED_CAPSL) state 0
Event code 2 (LED_SCROLLL) state 0
Event code 3 (LED_COMPOSE) state 0
Event code 4 (LED_KANA) state 0
Key repeat handling:
Repeat type 20 (EV_REP)
Repeat code 0 (REP_DELAY)
Value 750
Repeat code 1 (REP_PERIOD)
Value 80
Properties:
Event: time 1677377222.895324, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0041
Event: time 1677377222.895324, type 1 (EV_KEY), code 353 (KEY_SELECT), value 1
Event: time 1677377222.895324, -------------- SYN_REPORT ------------
Event: time 1677377223.045331, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0041
Event: time 1677377223.045331, type 1 (EV_KEY), code 353 (KEY_SELECT), value 0
Event: time 1677377223.045331, -------------- SYN_REPORT ------------
Event: time 1677377227.775421, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0041
Event: time 1677377227.775421, type 1 (EV_KEY), code 353 (KEY_SELECT), value 1
Event: time 1677377227.775421, -------------- SYN_REPORT ------------
Event: time 1677377227.885434, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0041
Event: time 1677377227.885434, type 1 (EV_KEY), code 353 (KEY_SELECT), value 0
Event: time 1677377227.885434, -------------- SYN_REPORT ------------
sudo nano /etc/udev/hwdb.d/haobo.hwdb
And enter the following EXACTLY as shown here (or copy and paste) including the single space before the “KEYBOARD”.
evdev:input:b0003v4842p1*
KEYBOARD_KEY_c0041=kpenter
Then press ctrl+x, then y, then enter to save and exit. Reboot and see if the button now works.
BGIYYZ
26 February 2023 02:30
25
I rebooted and it did not work. I wanted to be sure if I saved it properly so used sudo nano /etc/udev/hwdb.d/haobo.hwdb and it came back with the other line you asked me to type in (I actually cut and pasted it), so it seems too have saved okay.
For some reason, logging was enabled upon reboot. It wasn’t before
Can you copy the output of the following two commands and paste it in this thread…
ls -la /etc/udev/hwdb.d/
and
cat /etc/udev/hwdb.d/haobo.hwdb
You turned it on with the very first command I had you type. You can run that again to toggle it back off.
BGIYYZ
26 February 2023 02:45
27
osmc@osmc:~$ ls -la /etc/udev/hwdb.d/
total 16
drwxr-xr-x 2 root root 4096 Feb 25 21:41 .
drwxr-xr-x 4 root root 4096 Feb 25 21:42 ..
-rw-r--r-- 1 root root 54 Feb 25 21:41 haobo.hwdb
-rw-r--r-- 1 root root 607 May 26 2022 osmcrf.hwdb
osmc@osmc:~$ cat /etc/udev/hwdb.d/haobo.hwdb
Try this and see if it works…
evdev:input:b0003v4842p*
or maybe…
KEYBOARD_KEY_c0041=enter
BGIYYZ
26 February 2023 02:57
29
KEYBOARD_KEY_c0041=kpenter seems to have done the trick!!!
Thank you very much.
FYI kodi-send -a toggledebug immediately turns off logging, but it returns upon reboot.
Lastly, if I find I want to remap another button in the future, can you explain what you did or should I just ask again?
Again, thank you for all your help
I’ve seen that sometimes. Try turning it off and then tell Kodi to exit instead of rebooting. That normally does it for me.
So the issue here is that Kodi can’t handle any key that is using a number greater than 256 so to make this button, which was using 353 (left mouse button BTW) work we needed to assign it to a different key that is using something Kodi understands. Ideally something that is already keymapped to what you want. In this case we moved the mouse click to the keyboard enter key. The hwdb file changes these mapping at the operating system level. The first line in that file identifies which hardware devices are affected. Each line after that takes care of an individual key being remapped. To do another key just press the button in evtest and take note of the code that comes back. You can then enter a new line in that hwdb file using that number and using a key name from that very long list I had you post from evtest. You need to make sure each line has exactly one space and your using the same formatting scheme that I used, but you should be able to figure it out.
