puk78
1
Is there a possibility to create an interface indicator, indicating that a VPN connection has been established.
systemctl status openvpn
- openvpn.service - OpenVPN service
Loaded: loaded (/lib/systemd/system/openvpn.service; enabled; vendor preset:
Active: active (exited) since Thu 2018-11-01 20:03:40 CET; 1 day 15h ago
Process: 314 ExecStart=/bin/true (code=exited, status=0/SUCCESS)
Main PID: 314 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/openvpn.service
Nov 01 20:03:40 osmc systemd[1]: Starting OpenVPN service…
Nov 01 20:03:40 osmc systemd[1]: Started OpenVPN service.
That command simply says the daemon is running. It doesn’t say whether a connection is established
puk78
3
There is an VPN connection established,that’s for sure (PIA).
That isn’t reflected via your command however
puk78
5
Use this command to check VPN connection,and observe that Ip address has been changed/ hidden,assume that VPN connection is then established.
wget -qO- https://ipecho.net/plain ; echo
ping ¨Ip adress¨indicate connection to the PIA server
puk78
6
Solved install this Zomboided VPN Manager show my an pop-up when connection is established.
