I am writing an OSMC addon to scrape next bus arrival times from my local transit system. I have written this as a kodi script, and so far it works pretty well.
However, I received a `ConnectionError’ error from requests when I tried to run my script today (Kodi.log snip below).
A couple of online sources indicate this might have something to do with DNS servers.
source 1 - reddit
source 2 - stack overflow
As I say, the script has been working fine so I know the url generally works. DNS is managed by my router, and this seems fine too (again, given that things work properly every time other than today).
A reboot solved the problem, so it seems to have been just a temporary glitch. But I’d still love to know what happened so that I can make the script more robust. Any ideas what might lead to this issue? Would a pre-check for network being up help? Is there some way I can trigger network connectivity fixes from within Python?
Full debug Kodi.log here: http://paste.osmc.io/fopenebude.xml
(sorry, the log file is not minimal as I am unable to reproduce the issue. But the error happens around 11:50)
Python error snip below:
11:49:37 8895.619141 T:1643770912 INFO: initializing python engine.
11:49:37 8895.619141 T:1643770912 DEBUG: CPythonInvoker(9, /usr/share/kodi/addons/script.transit.nextbus/addon.py): start processing
11:49:37 8896.040039 T:1643770912 NOTICE: -->Python Interpreter Initialized<--
11:49:37 8896.041016 T:1643770912 DEBUG: CPythonInvoker(9, /usr/share/kodi/addons/script.transit.nextbus/addon.py): the source file to load is "/usr/share/kodi/addons/script.transit.nextbus/addon.py"
11:49:37 8896.041016 T:1643770912 DEBUG: CPythonInvoker(9, /usr/share/kodi/addons/script.transit.nextbus/addon.py): setting the Python path to /usr/share/kodi/addons/script.transit.nextbus:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
11:49:37 8896.041016 T:1643770912 DEBUG: CPythonInvoker(9, /usr/share/kodi/addons/script.transit.nextbus/addon.py): entering source directory /usr/share/kodi/addons/script.transit.nextbus
11:49:37 8896.041016 T:1643770912 DEBUG: CPythonInvoker(9, /usr/share/kodi/addons/script.transit.nextbus/addon.py): instantiating addon using automatically obtained id of "script.transit.nextbus" dependent on version 2.14.0 of the xbmc.python api
11:50:00 8918.881836 T:1643770912 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class 'requests.exceptions.ConnectionError'>
Error Contents: ('Connection aborted.', gaierror(-2, 'Name or service not known'))
File "/usr/share/kodi/addons/script.transit.nextbus/addon.py", line 87, in <module>
main()
File "/usr/share/kodi/addons/script.transit.nextbus/addon.py", line 68, in main
user_prediction_set = getTransitSchedule()
File "/usr/share/kodi/addons/script.transit.nextbus/addon.py", line 53, in getTransitSchedule
full_prediction_set = ttc.getPredictions(routes_of_interest_params)
File "/usr/share/kodi/addons/script.transit.nextbus/resources/lib/ttc_route_finder.py", line 63, in getPredictions
predictions = getNextBusData(parametersForMultiStops)
File "/usr/share/kodi/addons/script.transit.nextbus/resources/lib/ttc_route_finder.py", line 15, in getNextBusData
r = requests.get(base_url, params=payload)
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 60, in get
return request('get', url, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 49, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 457, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 569, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/adapters.py", line 407, in send
raise ConnectionError(err, request=request)
ConnectionError: ('Connection aborted.', gaierror(-2, 'Name or service not known'))
-->End of Python script error report<--
11:50:00 8918.911133 T:1957687856 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
11:50:00 8919.106445 T:1643770912 INFO: Python script stopped
11:50:00 8919.106445 T:1643770912 DEBUG: Thread LanguageInvoker 1643770912 terminating
11:50:01 8920.120117 T:1736176672 DEBUG: webserver: request received for /jsonrpc
11:50:06 8924.410156 T:1957687856 DEBUG: Previous line repeats 2 times.
11:50:06 8924.411133 T:1957687856 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
