Has been happening more often now. This time SSH did work to restart the mediacenter. Log uploaded as odakabidum.
Itâs a big log but nothing stands out as being âobviouslyâ wrong.
The system journal shows very little until you SSHâd to the box to restart mediacenter:
Oct 27 20:58:39 osmc kernel: hdmitx set channel status
Oct 27 20:58:39 osmc kernel: hdmitx: audio: Audio Type: PCM
Oct 27 21:12:44 osmc systemd[1]: Starting Cleanup of Temporary Directories...
Oct 27 21:12:44 osmc systemd[1]: Started Cleanup of Temporary Directories.
Oct 27 23:10:55 osmc sshd[10154]: Accepted password for osmc from 192.168.1.3 port 6758 ssh2
Oct 27 23:10:55 osmc sshd[10154]: pam_unix(sshd:session): session opened for user osmc by (uid=0)
so I assume that the freeze occurred a short time before 23:10.
Equally, the Kodi log doesnât offer very much for this timeframe:
18:07:20.998 T:4107517952 NOTICE: NFS is idle. Closing the remaining connections.
21:00:22.933 T:4107517952 NOTICE: VideoPlayer: Opening: pvr://channels/tv/Alla kanaler/pvr.hts_72879703.pvr
21:00:22.934 T:4107517952 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:00:22.934 T:3455476720 NOTICE: Creating InputStream
21:00:43.649 T:4107517952 NOTICE: CVideoPlayer::CloseFile()
21:00:43.649 T:4107517952 NOTICE: VideoPlayer: waiting for threads to exit
The only thing I noticed is a relatively large (2.2%) number of dropped packets on eth0:
RX packets:13913065 errors:0 dropped:306621 overruns:0 frame:0
This might be because of a network-related problem or something as benign as receiving IPv6 packets. Iâve no way of knowing.
Perhaps someone else will spot something I missed.
Fixed this a week or so ago.
Staging has the fix â update will be released on Sunday
OK. So probably not the cause of the crash then? Just out of curiosity: Does the Vero have a watchdog?
Did you install the fix from staging?
Thereâs a watchdog but itâs not used (same as on Pi)
Not yet. Do you recommend it or should I wait for the regular upgrade.
Itâs up to you â pushing it to release isnât far off now.
Well. Iâd like to keep my family so I will do it later
I often find my frozen when i come to use it, and yes a reset would be handy⌠unplugging the power fixes it⌠hopefully the updare gets it cured.
Hi Tom
That freezing shouldnât be happening but as discussed, it may be related to a specific addon youâre using.
Letâs get this resolved for you
