Hi, I wanted to start fresh so I moved my .kodi directory to a temp location. I started mediacenter up again and it all seemed new but when I was looking in myosmc the bluetooth settings from the previous setup were still there. Are they stored somewhere other than the .kodi directory?
The .Kodi folder is only storing Kodi’s userdata. Everything else would be according to whatever system services or applications store their information. In the case of bluetooth I think that would be in /var/lib under connman[something]. If you want to completely wipe the way to go would be a clean install and you can find out more following the “download” link at the top of this site.
