Hello,
Today i’ve installed the version 2017.12, and now at startup always reset the languaje to english.
it’s normal? thanks
Hello,
it’s normal? thanks
Might be the same problem some of us experience on the vero 4k:
I’d appreciate it if you could test this and provide feedback before we release this as an update to other users. To test this update:
/etc/apt/sources.list
I also recommend you edit /etc/apt/sources.list
again and remove the line that you added after updating. This will return you to the normal update channel.
ok, thank
