Reset Master Lock?
Hi, I locked the Settings on Vero V, but unfortunately have forgotten the numeric code.
i’m hoping there’s a command line method of retrieving or resetting the lock code, without resetting the Vero entirely?
nano ~/.kodi/userdata/profiles.xml
change the relevant lines to…
<lockmode>0</lockmode>
<lockcode>-</lockcode>
I’m pretty sure that will do it. If you had put some locks on sources there might be some lines to remove in sources.xml as well.
Many thanks - that worked!
