Reset to defaults option
I cannot find this option in OSMC, is it there somewhere?
That seems a bit vague to me.
What defaults were you wanting to set (there are a number, but no global setting - for that I think you would have to do a re-install)
Derek
To completely reset Kodi to defaults (including wiping the library and installed addon’s) you can just delete the .kodi folder.
Exit (not reboot) Kodi, press ESC when the OSMC splash screen shows up, log in with osmc/osmc then run:
rm -rf /home/osmc/.kodi/
Then type exit to return to Kodi. This does not do a fresh install of OSMC - you will still have all your recent OSMC updates and any other software you installed, only Kodi will be reset.
thanks for the info! just wanted to start clean on my kodi installation due to much unwanted addons installed over the years. thank u!
