Reset Vero 4K + from SSH?
I had a working Vero 4K + but it failed after running the update
Now it’s stuck ending in the sad face
I tried a USB stick and 3 different SD cards with the latest disk image
But it won’t update…
(fat, fat32, exfat? unzipped to OSMC_TGT_vero3_20201227.img)
I still have SSH access. How do I factory reset fromt here ?
sudu apt-get update
sudo apt-get dist-upgrade
mv .kodi .kodi.save
No luck with there…
What can I do now ?
Logs available at https://paste.osmc.tv/igahitojur
This will get you back to Kodi default settings. Enter the following commands with an SSH connection.
mv ~/.kodi ~/kodi.bak
systemctl start mediacenter
If needed you can restore:
mv ~/.kodi ~/kodi.bk2
mv ~/kodi.bak ~/.kodi
If your original setup was restored as expected and you want get rid of the unneeded clean install you can delete that with the following command.
rm -r ~/kodi.bk2
I already did that and it doesn’t work
But I managed to add a log in the original post
Why doesn’t it update from the SD card ?
I can see the SD card from SSH
Disk model: TransMemory
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: F766A81C-5E32-4155-8F1F-5219D3DAFA89
Device Start End Sectors Size Type
/dev/sda1 2048 60547071 60545024 28.9G Microsoft basic data
Let me answer my own question… What a noob
I just copied the image… Now with Rufus it looks better
Sounds like a step forward, let us know how you get on.
Thanks all, it’s back to health now
Besides me beeing a noob… The instruction could be a bit more detailed
There’s a “Make this page better” link on every Wiki page, everyone can contribute.
