My Vero 4k+ is running 320x200 or less. So bad I can’t read any text.
How can I reset the display settings to a default 720 or something so I can choose the CORRECT display settings, like a safe mode?
Did you change anything before this happened?
Otherwise there must be a problem with your EDID maybe a cable problem.
Suggest you connect via SSH and upload logs for the team to check with grab-logs -A and share the URL.
If you can read enough of the menu you also can do it via MyOSMC → Log Uploader
Thanks for the reply. Hadn’t changed anything. Leaving it unplugged for a while seems to have resolved the issue. I’m thinking more likely a fault of my AV receiver, as sometimes I get “unsupported signal”.
As part of the RetrOSMCmk2, we have made a tvservice(command from pi, that handles display and audio) look a like for the Vero4k(+), there are two versions.
One for 3,14 kernel (standard install), that can list your TV/AVR’s supported resolutions and set one, from shell:
wget https://raw.githubusercontent.com/hissingshark/retrOSMCmk2/master/resources/tvservice-shim.sh chmod +x tvservice-shim.sh ./tvservice.sh -m CEA ./tvservice-shim.sh e "CEA 16"
16 is a guess of mine, after you run -m CEA you will get a list of modes to choose from.
Here you have tvservice for 4.9 kernel (still experimental kernel) and the comming Buster release of OSMC:
wget https://raw.githubusercontent.com/zjoasan/retrOSMCmk2/master/resources/tvservice-shim_4_9.sh chmod +x tvservice_shim_4_9.sh ./tvservice_shim_4_9.sh -p
-p sets the TV/AVRs preferred resolution, else you can go with -m CEA or DMT and get a list of supported resolutions.
