I purchased this for the HDR as my Win set up had the resolution but not HDR.
I assumed the Vero V would allow the proper settings out of the box but as you see the selection does not mach the capability of the TV. My HDMI cable is proper for what I am trying to achieve.
Yes, you are! You are missing an EDID from your TV. Try a different HDMI cable and/or clean the contacts of the cable with contact cleaner. If no change, try a different HDMI input on the TV.
Thanks guys,
Cleaned the ports, tried all ports but the earc. Then tested a new cable. Which was to short for permanent use. All modes available.
That was it, bad cable. First one I have had fail. It was about 4 or 5 years old.
Looks like I am fishing a cable through the wall this weekend.
